rinku2012
Nov 30, 2017Tutor
Devices not connecting to Sattelite
Hello, Recently i have purchased Orbi ( 1 Router and 2 Sattelites). I have R8500 router in my 3 story town home. I have router in my 2nd floor. I have setup orbi as AP and kept sattelites in 1st...
rinku2012
Nov 30, 2017Tutor
can i keep my Orbi router on 1st floor and satellites on 2nd and 3rd floor and enable daisy chain. will this help me in any way ?
- st_shawNov 30, 2017Master
I would keep your Orbis where they are. Many devices need to be reset, or power cycled, before they will connect to the correct Orbi. You will need to do this after every Orbi reboot or power loss. Cameras and laptops are like that. This is a device issue not an Orbi issue. Phones should roam properly.
- rinku2012Nov 30, 2017Tutor
i have around 55 devices in my home ( cameras, ipads, tv, ps3, phones, laptops etc). if this is the case then whats the use of orbi.
can i use my old router (make it as AP) and keep it in my 1st floor . will the devices on 1st floor then connect to my old router ?
- st_shawDec 01, 2017Master
Most phones are designed to roam, and will switch quickly to the nearest/strongest AP as the environmnet changes. Many other devices do not operate this way, such as cameras and laptops. For example, OSX devices do not switch APs until the AP they are connected to drops below -75 dBm RSSI. So, if an OSX device connects to the Orbi router on the middle floor, you can move it right next to an AP on the 1st floor, and the OSX device will not switch APs.
I've noticed that when Orbi starts up, the router will boot first and the satellites will come up 30 seconds or more later. This means all the "sticky" devices in your network that do not roam properly (cameras, laptops, etc.) are going to connect to the router (because they see it first) and stick there. So, you must cycle the WiFi on the sticky devices after all your APs are booted and become stable.
You probably could use your old router as an AP, but you shouldn't need to do that with Orbi.
