xenon77's avatar
xenon77
Devices not correctly listed
Hi Community
i have an issue in IOS Orbi App since i moved to Router Mode.
My devices are not listed correctly all the time. IP in place of MAC, MAC in place of 2.4Ghz etc ... this is a mess
please check the screenshot
Can you please help ?
  • Yes, it’s a mess alright since the latest firmware update. I’ve logged in remotely just there using the iOS app and it is showing zero devices listed even though there is a satellite connected and the internet is showing as available and I can log into my Ring cameras/doorbell remotely over cellular data.
    • xenon77's avatar
      xenon77
      I was thinking about hard resetting the Orbi Router
      Not sure about the result .
      Is there a risk ?
      • FURRYe38's avatar
        There some problems that NG is aware of surrounding the devices and how they are being listed. Do a backup configuration to file then try a reset and setup from scratch to see if anything changes. If not, re-apply the back up and you'll be back to where you started.
        Is there a risk ?
  • Anonymous's avatar
    Anonymous
    xenon77 wrote:
    Hi Community
    The app is NOT recommedned.  What firmware are you sing?
        Anonymous
        xenon77 wrote:
        i am using the latest Firmware V2.3.5.30
        Initially there were reported problems with V2.3.5.30.
        My advice, if your system is basically working, forget about it.  Don't get to spun up about a UI shortcoming.
  • Device Manager displays a list of all devices that are installed on a Windows XP-based computer. When you view device information in Device Manager, you may see a device listed as Unknown Device next to a yellow question mark upsers
