ryanaroha
Nov 04, 2019Star
DHCP - How to release IP on RBS50 satellite?
My satellite connects to the base router via wireless backhaul. Base router has DHCP enabled. First time I turned them on, the satellite requested and received a DHCP address. I wanted to change ...
CrimpOn
Nov 04, 2019Guru - Experienced User
I had a similar problem back in 2017, where an IP camera kept an IP despite having a different IP in the LAN setup table:
https://community.netgear.com/t5/Orbi/How-to-Force-New-IP-Through-DHCP/td-p/1327677
Solving it was cumbersome and frustrating. What I did was create an IP assignment giving the offending number to a different device. Powered off the camera, then powered on the new device. Orbi said, "Hello there. I see you are supposed to have this IP address." and gave it out to the new device. Than, I powered on the camera. Orbii said, "Hello there. I see you want an IP that someone already has, so I will give you the one assigned to you in the table."
I was never confident that (a) I understand how DHCP is "supposed" to work, and (b) that my solution was even close to appropriate.
But, it worked.
- CrimpOnNov 04, 2019Guru - Experienced User
p.s. I know that the Orbi does not "speak". My imagination runs away with me at times.
