NetworkEng
Jan 11, 2019Aspirant
DHCP leases not persistant after restart
I work with IP set top boxes, home networks, etc. Recently I upgraded a MoCA based network that had individual access points to Orbi hoping to take advantage of a mesh network. Unfortunately I've r...
ekhalil
Jan 11, 2019Master
st_shaw wrote:
....... Hard coding IPs into devices could cause problems, if the hard coded addresses were within the DHCP range of Orbi.....
NetworkEng If you set static IP addresses in the devices then please make sure these addresses are outside the Orbi's DHCP range, but within the LAN segment (the set netmask in Orbi)
NetworkEng
Yes, my DHCP ends at .199 and static assignments are above that.
What you describe doesn't make sense though. Devices receive addresses via DHCP and will hold onto the addresses until the lease expires. Clients don't know the Orbi rebooted and restarting Orbi doesn't cause your devices to request new addresses.
Devices do receive addresses from DHCP and typically renew at 50% of lease time. Clients DON'T know the Orbi rebooted and so they keep using their address. Meanwhile the Orbi starts handing out these already in use addresses to new clients. This is the problem I'm trying to get to and hoping somebody from Netgear sees it because it's got to be impacting lots of people. I bet this is one of the reasons many people seem to be loading old firmware. Most devices seem to detect the IP conflict and re-initiate DHCP so the problem resolves fairly quickly but a few devices will hold their address for a long time and so conficts can persist.
Anybody running in Router mode is free to try this. Look at the addresses assigned under attached devices, then do something to restart the router. Go back and see if devices still have the same addresses. I bet not.
