DougB628
Jan 24, 2019Apprentice
DHCP not working properly, log filling with DHCP assignments
So I have noticed that after rebooting, sometimes DHCP doesn't work properly. No devices that use DHCP, whether they have a DHCP reservation or not, get DHCP assigned IP addresses. Whenever this prob...
DougB628
Jan 28, 2019Apprentice
My cable modem is an Arris Surfboard. I purchased it myself from Amazon, it was not provided by my ISP. It definitely has no DHCP functionality. No other devices on the network that can provide DHCP, at least not that is enabled. The other indication that it is the Orbi's problem is that it resolves itself after resetting DHCP a few times. Sometimes only one reset (turn off DHCP, apply, turn on DHCP, apply) is needed, other times it's two, three, or four times. Once it stablizes, it's 100% good for quite a while. I'm still learning what changes I make can trigger at least partial resets of things, and there are definitely things that appear to reset DHCP (I see my phone lose its wifi in these cases), and then it's a crap shoot as to whether it will come back stable or not. So I've definitely learned to leave everything alone if its working. I need to build trust back up from my wife - at this point she thinks either that I just want to play with it, and don't give a damn how it affects everyone, or that I truly have no clue what I'm doing. I know the first one is not right... jury is still out on the second...
Jan 28, 2019Guru - Experienced User
What is the Mfr and model# of the ethernet switches are you using in the configuration?
- DougB628Jan 28, 2019Apprentice
I have three switches, they are all TrendNet unmanaged switches. Two are model number TEG-S82g H/W:V2.0R, the other is model number TEG-S80g H/W:V2.1R
Only one of the TEG-S82g switches is actually in use at the moment. All three of them are 1GB/100MB/10MB capable.
- FURRYe38Jan 29, 2019Guru - Experienced User
I see this one switch as green ethernet:
https://www.trendnet.com/products/product-detail?prod=570_TEG-S82g
As mentioned before I believe, Orbi systems don't seem to get along with anything with Green Ethernet:
https://community.netgear.com/t5/Orbi/switching-requirements-for-ethernet-backhaul/m-p/1653718/highlight/true#M43817
https://community.netgear.com/t5/Orbi/Ready-to-chuck-this-system-through-the-window/m-p/1658470/highlight/false#M44394I would remove ALL switches from the ORbi system temporarilty and see the problem continues.
- DougB628Feb 01, 2019Apprentice
I have intentionally left my setup as is, with no configuration changes, and it has been stable for almost a week. To me, this proves that the "green" switches have nothing to do with this issue, and that any issue is related to DHCP being re-initialized and there being a chance that when it is re-initialized, it has a chance of starting up in an unstable state. By not making any configuration changes, and seeing my Orbi system remain stable the entire time, I think I have proven that the TrendNet switches are highly unlikely to be related to any issue.
