Wodpqldcmff
Jul 15, 2017Tutor
DHCP Server on Orbi - Configure additonal DNS Servers???
Hello - By default, it looks to me that DHCP clients on the network receive the Orbi's LAN IP address for DNS server when DHCP is enabled. The Orbi is DNS forwarding using the Internet Setup bas...
raven_au
Jul 15, 2017Virtuoso
Wodpqldcmff wrote:Hello -
By default, it looks to me that DHCP clients on the network receive the Orbi's LAN IP address for DNS server when DHCP is enabled. The Orbi is DNS forwarding using the Internet Setup based DNS entries. Is there any way for me to specifiy additional DNS servers for my DHCP clients to receive? I want the first DNS server to be a local A/D server, then additional DNS servers to be based upon Internet Setup based DNS entries, or something close to that.
Yes, interesting question.
I think the only way you might be able to achieve that is to not use the router DHCP.
Perhaps you could use the AD server as the DHCP server and disable DHCP on the router if there's sufficient functionality in AD.
Ian
