LSUMeathead
Jul 17, 2019Follower
Direct wired satellite keeps trying to connect to router wirelessly
I'm having trouble getting my setup right & it is frustrating because it should be ridiculously simple. I have a three level house. My cable modem is plugged dirrectly into my RBR50 router & both...
CrimpOn
Jul 24, 2019Guru - Experienced User
LSUMeathead wrote:The satellite cycles through, boots up, and glows blue. Orbi shows that it is hardwired, but then it flips back to wireless & the status is amber (poor signal) because it's wirelessly trying to connect to the router or daisy chain off another satellite in a room that already receives a poor signal from outside.
This is the puzzler. "Turns blue and shows hardwired, but then...."
One way to check the ethernet cable is attached a computer (laptop?) to the cable and see if it connects to the router successfully.
Are the RBR50 and the RBS30 on the latest firmware?
