HoopSpin
Dec 04, 2016Aspirant
Disable Beamforming
Forgive the basic question. I've read a number of posts regarding an issue I'm having with the Orbi dropping connection to Nest Cameras. Many have suggested a solution of disabling beamforming, at least until a firmware update may address the problem. I'm not seeing this option in Advanced Settings. Could someone please provide the path?
thanks
Go to the Tab Advanced
Then to Advanced Setup
Then to Wireless Settings
Scroll down - second line from bottom
- HoopSpinAspirant
Thank you for the response.
On this tab, I see three groups:
Advance Wireless Settings (2.4GHz b/g/n)
Advance Wireless Settings (5 GHz 802.11 a/n/ac)
Back haul Password
The second from the bottom is Trasnsmit Power Control under the 5GHz grouping. I don't see a reference to Beamforming on the page. Am I in the right spot?
Yes, on that page, the bottom line reads enable MU-MIMO. The line above that says enable implicit Beamforming. At least it does on my system.
