Michael512
Oct 17, 2016Follower
Disable DHCP on the ORBI
I would like to add a IoT firewall (CUJO) to my network, however they require I disable DHCP on the ORBI. How do I do that? Or is it even possible? I have the MAC Addr for the CUJO.
rhester72
Oct 17, 2016Virtuoso
You can put it into AP mode, which will disable both DHCP and DNS, but that assumes you have some sort of router/edge device sitting in front of it on your network. At that point, it will act as nothing but a WiFi bridge to your network, assuming all other services are provided by another device.
Rodney
