Michael512
Oct 17, 2016Follower
Disable DHCP on the ORBI
I would like to add a IoT firewall (CUJO) to my network, however they require I disable DHCP on the ORBI. How do I do that? Or is it even possible? I have the MAC Addr for the CUJO.
peteytesting
Oct 18, 2016Hero
Michael512 wrote:I would like to add a IoT firewall (CUJO) to my network, however they require I disable DHCP on the ORBI. How do I do that? Or is it even possible? I have the MAC Addr for the CUJO.
before you consider the cujo you might just want to read
being fully could based
CUJO costs $99, which includes a 180 day trial license. After that, you need to pony up $8.99 / month, $26 for three months, $49 for six months or $80 for a year of service. If you're a true CUJO believer, you can opt for a lifetime subscription for $800.
so unless you are willing to fork out $800 for the lifetime subscription they gave you trapped
the dual nat issues are also a concern
i just think its prob overkill for a home based solution and expensive and cloud based , if you are concerned by security why would you want your data being read or stored on the cloud
pete
- dpdurstOct 22, 2016Luminary
From what I see just untick the box that says use DHCP and your then all static assignments. Seems pretty straight forward on the Orbi
- peteytestingOct 22, 2016Hero
dpdurst wrote:From what I see just untick the box that says use DHCP and your then all static assignments. Seems pretty straight forward on the Orbi
this aproach would see anything connected behind the orbi would have to deal with dual nat , sure it may work for basic stuff but things that need 2 way communications like games and torrents etc etc would have issues
I would agree but from I see with the Cujo it's only handing out DHCP, say nothing about being a router so if that is the case there is no double nat happening. If in fact it is a router then your right of course it would be a double nat going on
