Michael512
Oct 17, 2016Follower
Disable DHCP on the ORBI
I would like to add a IoT firewall (CUJO) to my network, however they require I disable DHCP on the ORBI. How do I do that? Or is it even possible? I have the MAC Addr for the CUJO.
dpdurst
Oct 22, 2016Luminary
From what I see just untick the box that says use DHCP and your then all static assignments. Seems pretty straight forward on the Orbi
peteytesting
Oct 22, 2016Hero
dpdurst wrote:From what I see just untick the box that says use DHCP and your then all static assignments. Seems pretty straight forward on the Orbi
this aproach would see anything connected behind the orbi would have to deal with dual nat , sure it may work for basic stuff but things that need 2 way communications like games and torrents etc etc would have issues
- dpdurstOct 22, 2016Luminary
I would agree but from I see with the Cujo it's only handing out DHCP, say nothing about being a router so if that is the case there is no double nat happening. If in fact it is a router then your right of course it would be a double nat going on
- peteytestingOct 22, 2016Hero
dpdurst wrote:I would agree but from I see with the Cujo it's only handing out DHCP, say nothing about being a router so if that is the case there is no double nat happening. If in fact it is a router then your right of course it would be a double nat going on
if its handling firewall duties it has to be a nat and router as a firewall is the front door to the nat and thus there will be double nat
