Michael512
Oct 17, 2016Follower
Disable DHCP on the ORBI
I would like to add a IoT firewall (CUJO) to my network, however they require I disable DHCP on the ORBI. How do I do that? Or is it even possible? I have the MAC Addr for the CUJO.
dpdurst
Oct 23, 2016Luminary
I would agree but from I see with the Cujo it's only handing out DHCP, say nothing about being a router so if that is the case there is no double nat happening. If in fact it is a router then your right of course it would be a double nat going on
peteytesting
Oct 23, 2016Hero
dpdurst wrote:I would agree but from I see with the Cujo it's only handing out DHCP, say nothing about being a router so if that is the case there is no double nat happening. If in fact it is a router then your right of course it would be a double nat going on
if its handling firewall duties it has to be a nat and router as a firewall is the front door to the nat and thus there will be double nat
