axelrider's avatar
axelrider
Initiate
Sep 12, 2016
Do all satellites link back to base?
Hi, if more than one satellite is used, does each one have to connect back to the base unit, or can one satellite daisy chain from another?
  • hi guys
    the answer is that at the present time all sats connect back to the router only , they do not at this stage communicate between each other
    so at this stage the orbi is star topology
    i believe it may be planned to run the orbi and its sat's in a true mesh type topology in the furure but not at this present time
    this is usually not an issue if you can place the orbi router between the sat's as in
    sat ------ router ------sat
    pete
    • CrimpOn's avatar
      CrimpOn
      When the Orbi product was released in 2016 "Daisy Chain" connection of satellites was not supported.  That feature was implemented YEARS ago.
      (sometimes message threads from seven years ago are not longer useful.)
  • ChristineT's avatar
    ChristineT
    NETGEAR Employee Retired
    Hello Axelrider!
    Thank you for your question and welcome to the community!
    At this time, the Orbi kit only includes the Router and one (1) satellite.  Orbi WiFi System can support up to three (3) satellites. Additional satellites will be available for purchase in due course. I encourage you to submit this idea on our Home Networking Ideas Exchange forum and vote for this idea. The more votes, the more likely the feature will get implemented.
    We would love to hear any additional feedback you have about Orbi and how you like it!
    Best Regards,
    ChristineT
    • axelrider's avatar
      axelrider
      Initiate
      Hi ChristineT,
      Thanks for the reply, however it didn't really answer the question. Please let me know if using more that one sattelite does satellite 2 or 3 connect to the base unit, or can they be "daisy changed" to extend range.
      Thanks
      • peteytesting's avatar
        peteytesting
        Hero
        hi guys
        pete
