Droidvideo
Nov 20, 2018Aspirant
Do you recommend using ethernet backhaul connections
Hi
My home is pre-wired with Cat6 cables and I have RJ45 ports available where I want to place my Orbi satellites. Currently I have RBK50 router with two satellites configured without ethernet back...
Droidvideo
Thanks for all the great pointers and for confirming it is working as expected.
I don't remember messing with daisy chain setting. It should be set to whatever is factory default.
Nov 20, 2018Guru - Experienced User
Ok, if you experience any issues with wired back haul. Try this setting first to see if it helps.
Enjoy.
