fgard
Nov 01, 2020Aspirant
Does anyone know if the Orbi RBR40 will work with the BT Smarthub 2?
BT want us to upgrade from the homehub 3.0 to the Smarthub2. We currently have a separate modem with the homehub.
Looking at the connectors on the Smarthub2 this seems to replace the modem as well so it's not clear how we would connect it all up. As the Smarthub2 seems to have been produced so BT could offer an Orbi equivalent system it leaves us wondering if the two are compatible.
Any help or guidance gratefully received
If the modem or ONT have a built in router, This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options with Orbi systems,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
https://kb.netgear.com/26765/Disabled-Features-on-the-Router-when-set-to-AP-Mode
