steeve725
Mar 12, 2019Guide
Does anyone use Surge Protectors for there Plug In Satellites?
Hi, Everyone
Just got an orbi RBK33 last week with the 2 plug in satellites.
Does anyone use surge protectors for there satellites? If so can you give me a few recommendations?
My ...
Mar 12, 2019Guru - Experienced User
You can. TripLite are good ones. What do you use now for the RBR?
- steeve725Mar 12, 2019Guide
For my RBR I use an APC surge arrest. I was thinking of a single outlet surge protector for the satellite, but finding one that isn't very big so I could still use the other outlet if I needed to.
- tagteamMar 12, 2019Virtuoso
Just another data point, but I have one RBR50 and two Sats with each unit on a separate UPS.
That's probably overkill but then I have never had even one issue with the system.
- gr8shoMar 13, 2019Virtuoso
This, It would equally make sense to have ISP equipment on UPS as well.
Unfortunately the VRAD in my neighborhood is defective and whenever a temporary power interruption happens, have to wait 20 minutes for the box to reboot. Fiber can't get here soon enough.
