msfox99
Feb 26, 2020Guide
Does each Orbi satellite have to "see" the router?
Hi - just a question about how the Orbi system works. Does each satellite have to be close enough to the router to have a good signial with it, or just close enough to the nearest other satellite? i.e. is it kind of a daisy chain?
Thanks.
1 Reply
30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-router
Or you can enable Daisy Chain on the RBR and set your RBS out in a line from each other so they piggy back off each other in a Daisy Chain.
