DavidRansier
Jul 26, 2017Follower
Does Orbi RBK50 support USB Connected hard drives?
I have the latest firmware installed (V1.12.0.18).
I’ve read a lot of conflicting reports, so its confusing. Does the Orbi RBK50 currently support USB connected hard drives, or should I only connect a NAS hard drive?
Thanks,
David R
- captain_phaserApprentice
DavidRansier wrote:I have the latest firmware installed (V1.12.0.18).
Thanks,
David R
The Orbi's USB functionality was only just enabled 2 weeks ago and it currently only supports USB connected printers.
- RickWireInitiate
I also have been asking when my orbi would support USB connected drives. Do we have any updates as to when this will happen? Running firmware v2.0.0.74.
- shawnb2Initiate
I'd like to know as well. I recently bought this system figuring as any other router in the last few years that I've used I been able to use it with a USB hard drive to use for Time Machine. This has been a question from what I've been reading for a year. What's going on Netgear? How can this not be a top priority for such a popular system? It's bad enough it's onlt 2.0, but at least give us something. I'm using firmware V2.0.0.74.
- BobDukeApprentice
I did a bit of experimenting as I too read conflicting reports.
USB thumb drive - worked
USB hard drive - worked
I was able to access (read & write) from Windows 7 and Android devices.
Drives could be attached to either the router or satellite.
There may be an issue with the USB port providing adequate power to hard drives.
I did not test with a physically large hard drive, just smaller, pocket sized units.
Running 2.1.1.16.
