DavidRansier
Jul 26, 2017Follower
Does Orbi RBK50 support USB Connected hard drives?
I have the latest firmware installed (V1.12.0.18). I’ve read a lot of conflicting reports, so its confusing. Does the Orbi RBK50 currently support USB connected hard drives, or should I only con...
Rapa97
May 09, 2018Initiate
But have you been able to access the drive from your PC or Mac for example? How you know the address to access it? Or login info?
Sundreamer
Jun 10, 2018Star
Same here, I would like to connect a usb drive for my sonos system (I did this on my old linksys)
How can I do that ?? I don't see any option to do it
- overbyeJun 16, 2018Aspirant
I'm in the same boat, just installed my new Orbi but wondering how to hook up something for time machine to connect to. There are three of us in the house needing to use this. What is an NAS hard drive and how would it work?
- FURRYe38Jun 16, 2018Guru - Experienced User
I beleive the USB port is only for printers currently. Something NG is still reviewing or working on I guess.
NAS is a separate device that has from two up to 4 or more drive bays. This unit has built in networking features. Users install hard drives into these units and use this to store there data on. Then connect these devices to there networks and can share out the data using different configurations.
- SundreamerJun 16, 2018StarFat 32 128gb works to put music for sonos
