DavidRansier
Jul 26, 2017Follower
Does Orbi RBK50 support USB Connected hard drives?
I have the latest firmware installed (V1.12.0.18). I’ve read a lot of conflicting reports, so its confusing. Does the Orbi RBK50 currently support USB connected hard drives, or should I only con...
GadgetVirtuoso2
Jun 17, 2018Apprentice
Sundreamer wrote:
Mean ntfs may not work but fat 32 will
Can’t understand why they don’t support ntfs
Because then they would have to license it from MS, FAT32 is an open standard that requires no licensing. MacOS can't write to an NTFS drive for the same reason without third party software.
Sundreamer
Jun 17, 2018Star
well, you may be right but I had a linksys prior the orbi supporting ntfs and no problem to copy large files from a macbookpro on the network.
Fat 32 is outdated, no support for large files.... is exfat also under lisence ? anyway I may be wrong but my old router was perfectly working with ntfs and I am quite sure that it's not so difficult to offer this features to people in compare to the price of the orbi routers.....
this is my opinion but my linksys was 1 third the price of my orbi's
This sayed, I am really happy with the wifi of obi's that's working like a charm.
let's just add support for exfat or ntfs.... (both like fat 32 are Microsoft isn't it ???)
- AndyxAug 23, 2018Guide
I have the same problem/question regarding USB file sharing. It worked great on my WNDR4300 so when I upgraded to the Orbi I was completely shocked to find it did not support the same functionality. However, I was told it was coming.
I just got off the phone with Orbi support (after an extremely long wait on hold) and was told that file sharing is still not suported.I hate to have to downgrade the Orbi, becasue it works well as a wifi router, but I purchased it expecting to have the same file sharing I had on the earlier device. I don't know how to get Netgear management's attention, but unless the fix this I will never purchase Netgear again.
- FURRYe38Aug 23, 2018Guru - Experienced User
- SundreamerAug 23, 2018Star
Well, for the price you pay you get F...
unfair and absurd
- OkipicDec 28, 2018Initiate
Hey,
do you know the current status of this question? It seems that in August 18, Netgear was planning to add this possibility to connect a USB-HardDrive to Router or Sattelite. Today I cannot find recent news.
Thank you for your help.
Okipic
- FURRYe38Dec 29, 2018Guru - Experienced User
No information. You might contact NG support and ask about this.
Okipic wrote:
Hey,
Okipic
- OkipicDec 29, 2018InitiateThank you for your answer. I will do.
Best regards.
