Srikanthl
Nov 06, 2017Initiate
Does Orbi RBK50 support USB3 Connected hard drives?
Hi, Does Orbi RBK50 support USB3 Connected hard disks? My router just can't recognise USB3 hard disks. However it is able to recognise my 8gb uab2 pen drive. Is this a limitation in current firmwar...
- Nov 07, 2018
Hi All,
I have checked this with the team. Orbi has not been updated to use Readyshare features as of right now it only officially supports Readyshare print for printers via the USB.Regards,
Blanca
Community Team
hilld83
Nov 06, 2017Star
Based on what can currently be found on Netgear's support site for this product, the USB port is for connecting a USB Printer to enable ReadyShare network printing. There does not appear to be any mention in this device's features to indicate support of USB hard drives at this time. While some users have reported very selective compatibility with USB hard drives or USB thumb drives, there does not appear to be a device compatibility list, nor have I found instructions for attaching USB hard drives, USB thumb drives, or other USB storage media to the RBK50 (RBR50 or RBS50). To my knowledge, there has also not been any official information given to indicate supported formats. For the time being, I would say that if this is a feature you need, you could try adding a device to your network that is designed to support this capability. For example, some NAS units have USB ports for adding external hard drives or thumb drives. As an alternative, most computers will allow network sharing of external hard drives or thumb drives. Suggestions for adding USB drives to your home network can be found by searching online. Hope this helps!
mdgm-ntgr
Nov 07, 2017NETGEAR Employee Retired
All our current ReadyNAS units have USB3 ports. We even have one/more eSATA ports on a number of models if you prefer that interface.
A NAS does need at least one disk installed internally. Performance for internal disks in network storage is likely to be be a lot better than USB disks. If you were thinking of permanently connecting a USB disk, a NAS connected to an ethernet port on your Orbi would be a much better way to go.
With a NAS you can use redundant RAID levels with multiple disks to make needing to do a full restore from backup less likely. Whereas with a USB disk if the disk fails you’ll need to restore a copy of the data elsewhere.
A NAS is a headless PC with its own CPU and can be used to do lots of different things.
- SrikanthlNov 07, 2017InitiateThanks but NAS is generally expensive. My USB3 device is backward compatible with usb2 port. Orbi has an usb2 port and so I thought it would support my USB drive.
Is it something that will be supported in future firmware updates ?
