Srikanthl
Nov 06, 2017Initiate
Does Orbi RBK50 support USB3 Connected hard drives?
Hi, Does Orbi RBK50 support USB3 Connected hard disks? My router just can't recognise USB3 hard disks. However it is able to recognise my 8gb uab2 pen drive. Is this a limitation in current firmwar...
- Nov 07, 2018
Hi All,
I have checked this with the team. Orbi has not been updated to use Readyshare features as of right now it only officially supports Readyshare print for printers via the USB.Regards,
Blanca
Community Team
Oct 11, 2018Guru - Experienced User
Did you factory reset the Orbi router after v210 was installed, then setup from scratch with the USB drive to see if it connected and available?
paddyr wrote:
Well....my usb 2 drive worked perfectly for many months and I used it as a backup drive for Carbon Copy (on a MAc).
I updated the firmware to 2.2.1.210 and never saw the drive again!
I reverted the firmware back to 2.1.4.16 and although sometimes I can see the drive, I have trouble connecting to it and have not been able to write to it. I'm not 100% sure what the firmware version was before I updated.... so I'm not sure if 2.1.4.16 was the version that actually worked previously.
In any case, for the sake of sanity and not wasting time on crap like this, I'm just going to go buy a network drive and plug it in to an ethernet port and get on with my life.
Blanca_O
Nov 07, 2018NETGEAR Employee Retired
Hi All,
Blanca
Community Team
