BillYoung
Jan 16, 2020Luminary
Does ORBI RBR50 work with GoNetspeed Standard (150 Mbps)
FurryE38 or whomever can help answer this question:
We are looking at going to highspeed internet from GoNetspeed. We are looking at the Standard service, which is 150 Mbps. So my question is this: will I have any issue with this upgrade of internet service on my RBR50?
Secondarily, will I have to keep my RBR50 in AP mode? I realize this is likely to depend on the modem provided by GoNetspeed.
Answers to these questions would be most appreciated. Thank you in advance.
Depending upon modem, modem only unit is recommended. If you get a gateway modem with built in router then you'll need to look into the following:
This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktopOtherwise, speeds will be fine. Mines on a 1Gb/50Mbps ISP service.
1 Reply
Couple of options,
