Spike13's avatar
Spike13
Guide
Nov 03, 2018
Does Orbi Use HT160 Larger Channel Widths?
What exactly are the capabilities of the Orbi system? I find their specs vague and misleading, but maybe that’s just me. For example, I have Spectrum Gig service, 940Mbps wired, and I am barely getting half that using WiFi over the Orbi router. I was doing better with Soectrums WiFi router (650Mbps). I’m using an Intel 9260AC WiFi card in my laptop.
So my first question is how can you configure Orbi router to use the larger channel widths which are necessary to achieve higher WiFi speeds? There are jonsettings for this that incan find. All I have found is enable Mu-MIMO which Inhabe turned on but that made absolutely no difference.
I’m not even connecting consistently at 867Mbps like I was with the Spectrum WiFi router.
Am I missing something, or is this really a system designed for someone looking for convenience as opposed to performance?
  • I could have worded this better. A simpler more straightforward way to convey my question is whether a link speed connection of 867Mbps is the best I can hope for with the Orbi. If so, then the rest is a moot point as this system is just not designed to handle the potential of Gig wifi speeds available at higher channel widths and I need to move on to a different system. In fact, I’m thinking I may be better off simply changing my NightHawk R7900 which is currently setup as an AP to perform the router duties.
    Many thanks for any responses.
  • Well, first, what speeds do you get connected directly to the modem when you do a speed test? Just because you're paying for gigabit internet, and ostensibly have a plan which provides it, doesn't mean you're actually getting it. Problems could include network congestion, an older modem that isn't capable of your plan's speeds, multiple devices using bandwidth at the same time (so, in aggregate, you'd be getting close to the full speed, but any single device could only be getting a fraction of it at any given time).
    Second, you can do a wired speed test via the Orbi router. Ideally, you want the testing device to be the only one connected and using any bandwidth, so no other devices connected via ethernet, and no devices connected via wifi. But you should get very comparable results doing wired speedtests when both connected directly to the modem and conected (via ethernet) to the router.
    Third, you do a wireless speedtest. But here, there may be some degradation. There's overhead for wifi, your results will depend on the distance between your router and device, what materials are in between (walls, floors, electrical wiring, pipes, ducts, furniture, appliances, people), and what other devices are causing radio interference (neighbors' routers on the same channel, sometimes microwaves, baby monitors, etc.).
    If step one gives you good results, and step two is comparable, but three is much worse, you could try respositioning your router/satellite(s)/devices, try finding a channel with less interference and specifying it (as opposed to using auto channel selection), making sure your microwave isn't in use while running the test, etc. You could also look at the wireless settings in the Orbi, and maybe consider performing a factory reset, reconfiguring the Orbi and a single device, then running the speedtest again.
    Tech specs are here and you should be able to get in excess of gigabit speeds both on the backhaul between router and satellite(s), and over the (wired or wireless) connection between your device and the Orbi, though this will, of course, depend on network conditions, how many other devices are connected, etc. But the system is capable of giving you the speed you want.
    • Spike13's avatar
      Spike13
      Guide
      Thanks for the detailed response. I’m getting 940Mbps wired from the Spectrum modem. I’m testing with nothing else connected or taking up bandwidth. I reliably had a link speed WiFi connection between my laptop (Intel 9260ac WiFi card) and the Spectrum WiFi router of 867Mbps, with actual speed tests in the 650Mbps range. I purchased the Orbi to do better and it’s doing less, link speed connections are sub 750Mbps and actual speed tests are sub 500Mbps.
      Most of your suggestions do not relate to the link speed connection between the laptop and the Orbi router. If the Wifi capabilities of the Orbi will only allow a max WiFi link speed connection of 867Mbps, the rest of the equation is moot. To do better than 867Mbps the Orbi has to be able to use the higher 5Ghz channel widths, of 80+80 or 160Mhz. I see no ability in the router settings to do this, at least not manually. Currently, it’s not doing this automatically either based on the sub 750Mbps link speed connection between the laptop and the Orbi router, sitting 8 feet away.
      Unless the Orbi can be configured to give higher linkspeed connections by using the higher 5Ghz channel widths, the rest doesn’t matter.
      Has anyone achieved higher than 867 Mbps link speed connections between their wireless devices and the Orbi router?
      • randomousity's avatar
        randomousity
        Luminary
        Ok, as best I can tell, the Orbi does not suport HT160, since it appears there are other Netgear routers that do, and the place where I think the setting would be visible on the Orbi (Advanced > Advanced Setup > Wireless Settings) doesn't show it as an option under either
        Advanced Wireless Settings (5GHz 802.11a/n/ac) or MU-MIMO (which is where it, apparently, appears on some other Netgear routers).
        So, I think the short answer to your question is "no." I don't know whether this is a hardware limitation, where you would need to buy a different router, or if this is something that can either be enabled via the command line over telnet, or in future firmware updates.
        ETA: I found reference to the HT160 setting on a different Netgear router here.
  • FURRYe38's avatar
    Current wireless performances and link rates will not support 1Gb speeds especially thruput speeds as wired 1Gb does. Wired will always have better performances and link rates then wireless. If you need 160 wireless then other routers that NG has do support 160. I can think of 3 of them off hand. The Orbi will never support 160 as it's intended design meets the criteria for MESH and better coverage and performances for this kind of system. Also 160 its still not a major protocol right now and is not common or widely used in the average home or average client side HW. Maybe as time goes and with the advent of wireless AX now on the horizon, will have to see how things go with new tech coming out next year.
    If you want and have need for 160 wireless, find you a router that supports it. NG has a few.
    I'm still waiting on 10Gb wired support for me. :smileyvery-happy:
    • aaronhritz's avatar
      aaronhritz
      Initiate
      It does support HT160, but not exactly out of the box. You need to use the 2nd 5g antenna array (4x4) to access HT160. You also need to set the proper region code to get access to the channels (or set it in UCI or DNI directly).
      root@RBR50:/# wlanconfig ath2 list active
      Channel 132 : 5660 *~ Mhz 11na C CU V VU V80-138
      Channel 136 : 5680 *~ Mhz 11na C CL V VL V80-138
      Channel 140 : 5700 *~ Mhz 11na C V
      Channel 149 : 5745 Mhz 11na C CU V VU V80-155
      Channel 153 : 5765 Mhz 11na C CL V VL V80-155
      Channel 157 : 5785 Mhz 11na C CU V VU V80-155
      Channel 100 : 5500 *~ Mhz 11na C CU V VU V80-106 V160-114
      Channel 104 : 5520 *~ Mhz 11na C CL V VL V80-106 V160-114
      Channel 108 : 5540 *~ Mhz 11na C CU V VU V80-106 V160-114
      Channel 112 : 5560 *~ Mhz 11na C CL V VL V80-106 V160-114
      Channel 116 : 5580 *~ Mhz 11na C CU V VU V80-122 V160-114
      Channel 120 : 5600 *~ Mhz 11na C CL V VL V80-122 V160-114
      Channel 124 : 5620 *~ Mhz 11na C CU V VU V80-122 V160-114
      Channel 128 : 5640 *~ Mhz 11na C CL V VL V80-122 V160-114
      Channel 161 : 5805 Mhz 11na C CL V VL V80-155
      Channel 165 : 5825 Mhz 11na C V
      It only really makes sense to do if you're running a wired backhaul or not looking for a mesh configuration. While you can convert the 1st array of 5g antennas to run the backhaul, with them being 866.7 Mb/s, it doesn't make a lot of sense if you're planning on ever having very high speed devices or a lot of devices connect to a satellite.
      Lots of interesting things you can do with Orbi if you spend a few long nights learning OpenWRT.
