wacky1215
Aug 06, 2017Follower
Does Orbi work with Google Fiber?
So we just got Orbi this weekend. It seems to be working fine, except it keeps dropping the internet from certain devices. Specifically my wife's phone, Galaxy 8. I had to redo the wifi connection on...
Techlore
Aug 06, 2017Apprentice
The Orbi base station should be plugged into a modem as it acts as a router.
If your wife's phone is the only problem them most likely the issue is with the phone, a setting or something my need to be changed.
- loomis1975Aug 06, 2017Luminary
Galaxy S8 and S8+ are known to have a problem staying connected to Orbi. Workaround for now until it gets sorted is to enable guest network and connect the S8 to that.
