jiism's avatar
jiism
Does RBK50 – Orbi AC3000 Tri-band WiFi System support PoE (Power Over Ethernet)?
Hi,
I just brought home RBK50 (2 units system) and have a quick question.
Does Orbi Wifi support PoE devices (e.g.  POE IP Security Cameras)? I did not find information in the PDF online manual.
Thanks.
  • Orbi does not provide PoE output power on any ports.  You can, however, connect a PoE-enabled switch to Orbi and power cameras that way.
    • jiism's avatar
      jiism
      Thanks. To Netgear Support team - if this information is not in the manual, this is a request to add it to the manual.
