thetwin's avatar
thetwin
Does RBR50 support USB connected HDD?
I would like to connect my encrypted USB drives to the Orbi RBR50. Is this feature currently supported? Thanks.
  • I know it beacause I talked to Netgear support about this feature and they told me it will be coming in future firmware updates.
  • Right now it is not supported but in the upcoming firmwares it will be supported.
    • DezM's avatar
      DezM
      Star
      How do you know HDD support is coming in future updates?
