MarkC1024
Feb 02, 2017Luminary
Does Router reboot Satellites?
Just curious if when you reboot the Router via the GUI, does it also initiate a reboot of the Satellite(s)?
- Feb 06, 2017
Hello MarkC1024
Yes and no Typically when you reboot it will refresh the connection from the main base to the satellite but it does not power cycle the satellite unit.
DarrenM
DarrenM
Feb 06, 2017Sr. NETGEAR Moderator
Hello MarkC1024
DarrenM
MarkC1024
Feb 06, 2017Luminary
Thanks for the reply Darren. Might be something for Engineering to consider as an option- reboot Router, reboot all
