DaveGee's avatar
DaveGee
Follower
Apr 15, 2018
Double NAT when there is no Double NAT
I have a device inside my LAN that is saying I have a double NAT. I have an ARRIS modem that has no router funcationality, and do have the Orbi set to hand out DHCP addresses. Yet I am getting a double NAT message. Anyone with similar issues?
  • What IP address does the Orbi have on its Internet port?  You can find it on the Internet Port panel in Advanced settings.  Post just the first half.
  • FURRYe38's avatar
    Where are you seeing this double NAT message?
    What is the Model# of the modem you have?
