MidTnMike41
Jan 21, 2019Aspirant
Download speed cut in half on wired connection
Hi,
I just installed my Orbi on a xfinity gigabit connection using bridge mode. When I plug my pc directy into the modem I get a speedtest of about 960Mbs down. When I plug my pc into the Orbi...
- Jan 24, 2019
Thanks for letting us know. Seems that you and others are noticing issues with the ISP services as well:
Glad they got it fixed. Please mark your thread Solved so others will know.
Enjoy now.
MidTnMike41 wrote:
My issue is resolved. Turned out to be a problem with xfinity. After rebooting everything and plugging PC directly into modem i was only getting 350Mbps from modem. After an hour on the phone they admitted my speed was wrong. They did something, i lost internet for a few min and it came up. I now get 950Mbps on my wired PCs through the Orbi. All is good. Make sure to check speed going in!
Jan 21, 2019Guru - Experienced User
What FW is currently loaded?
Is the Orbi system operating in Router or AP mode?
MidTnMike41 wrote:
Hi,
I just installed my Orbi on a xfinity gigabit connection using bridge mode. When I plug my pc directy into the modem I get a speedtest of about 960Mbs down. When I plug my pc into the Orbi I only get 350Mbs down. I tried changing the cable between my modem and the Orbi but still getting same speed. Has anyone else had this issue?
- MidTnMike41Jan 21, 2019Aspirant
It is running the latest firmware V2.2.1.210. Not sure of the model# of the modem, it's whatever Xfinity provides. I put it in bridge mode and the Orbi is in router mode.
