MidTnMike41's avatar
MidTnMike41
Download speed cut in half on wired connection
Hi,    I just installed my Orbi on a xfinity gigabit connection using bridge mode. When I plug my pc directy into the modem I get a speedtest of about 960Mbs down. When I plug my pc into the Orbi...
  • FURRYe38's avatar
    Thanks for letting us know. Seems that you and others are noticing issues with the ISP services as well:
    https://community.netgear.com/t5/Orbi/New-RBR50-Satellite-setup-some-thoughts-and-questions/m-p/1695200#M50774
    Glad they got it fixed. Please mark your thread Solved so others will know.
    Enjoy now.
    MidTnMike41 wrote:
    My issue is resolved. Turned out to be a problem with xfinity. After rebooting everything and plugging PC directly into modem i was only getting 350Mbps from modem. After an hour on the phone they admitted my speed was wrong. They did something, i lost internet for a few min and it came up. I now get 950Mbps on my wired PCs through the Orbi. All is good. Make sure to check speed going in!
