jcricket73
Oct 26, 2019Follower
Download speeds at 1/10th non-Orbi Wifi router since latest firmware
I had to replace a totally dead 2-month RBR50 (no amount of rebooting/factory resetting fixed anything). New RBR50 and 2 satellites arrive and get installed, all the connections work ok (can connect to the wifi, finds the satellites, etc) - but speed is 1/10th of what I'm getting if I connect to to the Orbi vs the modem/router from my cable company.
IOW - if I connect to Comcast's xb6 over wifi I get like 500Mbps (I've used Speedtest, etc) but if I connect to the Orbi (router or satellites) I get at best 50Mbps.
I've tried connecting over Ethernet, factory resetting, rebooting, etc. I saw a couple other folks saying the latest firmware might have caused this. I tried to downgrade, but it actually updated the firmware on the satellites back to the latest version before I could get to the router (LOL).
I don't even know what to do, I am about to chuck these into the sea, it's far worse than the janky Comcast router + standalone access point I used to have.
Any ideas before I give up and return these?
1 Reply
What is the Mfr and model# of the ISP modem the NG router is connected too?Modem Combo Units:
This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
