AngelicRocker
Dec 05, 2020Aspirant
Drastically reduced internet speed at night (RBR50)
So I bought and installed my Orbi system in January 2020 and loved it immediately, solved nearly all of my household's internet issues at the time. Cut to September 2020 and we have a Spectrum techni...
AngelicRocker
Dec 06, 2020Aspirant
As far as I can tell, nothing has changed. This problem only started 6 days ago and was never an issue before then. Nobody in the house is doing anything different than they are throughout the day either.
Slow down as in my 200mbps ISP plan that normally reports anywhere from 180mbps to 250mbps on both wired and wifi connections drops and reports anywhere from 600kbps to 10mbps. Only starting around 5 or 6 PM and lasting usually all night with some pockets of full download speed splashed in.
As far as someone gaining access to the network, the Orbi app isn't reporting any unknown devices connected.
Dec 07, 2020Guru - Experienced User
Has the ISP modem or ONT been powered OFF for 30 seconds then back ON.
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Modems/m-p/1530376#M12853
Could have yoru FW been updated 6 days ago if you recall?
AngelicRocker wrote:As far as I can tell, nothing has changed. This problem only started 6 days ago and was never an issue before then. Nobody in the house is doing anything different than they are throughout the day either.
- AngelicRockerDec 07, 2020Aspirant
I am not using an ISP modem. It's a Netgear CM600 connected to the Orbi.
It has been power cycled multiple times while testing this issue over the last few days. 3/4 tests connecting a PC directly to the modem via ethernet have reported full download speed too.
I have an ISP appointment in just under 2 weeks (unfortunately the soonest they had available), but I will note all of that to ask them specifically to check.
Update: As of this morning, internet speed was testing fine, tried to download a game, got about 10GB down in ~12 minutes, and then it completely slowed down again. Reporting 5mbps or less in the morning now, so the issue is not occurring at night only anymore.
- FURRYe38Dec 07, 2020Guru - Experienced User
So try upgrading to https://community.netgear.com/t5/Orbi/RBR50-RBS50-Firmware-Version-2-6-1-40/m-p/1997895/highlight/true#M105941
Or if that still fails, try v16:
I would factory reset and setup from scratch after the FW is applied.
