zafkir
May 23, 2018Aspirant
Dropped packets on RBR40
I have tried taking all satelites offline, changing the settings to Disable MIMO, Daisy Chain and Fast Roaming and IPv6. I've also tried firmware versions 2.0.0.56 and 2.1.4.10
Packets are regular...
May 23, 2018Guru - Experienced User
What are you pings if you connect your test PC to the gateway?
What are the results if you ping the Orbi router in AP mode?
Ensure your using good quality LAN cables. CAT6 recommended.
After updating FW, try a factory reset of the router and set up from scratch then run your ping tests...
