klp8466
Apr 10, 2018Guide
Dropping Connection
My model number is not listed here. Assuming, that's because I bought the router/satellite at Costco 'Orbi Mini RBR20 AC2200'. First night and everything dropped several times and I decided to go back to old router. Honestly, not sure what to do. I heard this was a great option, but so far within two hours of using it there has been nothing great about it. Any recommendations, would be greatly appreciated. If its to take the product back please let me know. Thank you so much!
- Retired_Member
you need to provide more info about your setup
modem?
placement?
stuff like that....
- klp8466Guide
I have TWC/Spectrum ARRIS TG1672G 300 Mbps. We had a netgear and the only issue I had was our sons PS4 after years of using it and everything else works fine. The netgear we have has less coverage then the Orbi Mini. So I was thinking if we upgraded perhaps it would work and it's actually worse, as it drops everything. So I'm sure something is not set up right. The orbi router we had on the main level of our home as that is where most of us use your computers and then the satellite in the basement for the gaming systems. The router would go white then at somepoint show no color and the sateltte would show light blue and lose its color as well. I assumed that was due to dropping the connection.
- Retired_Member
no color is good (if at one point it was blue). it basically means that it's running and all is well.
Here to help out. :smileywink:
