JohnHighrock
Jul 27, 2023Aspirant
Duplicate/Extend a RBK50 installed solution
Hello, Already equipped with a rbk50 system (router + 1 satellite) I would like to extend my wifi coverage. Can I install a second RBK50 system (router+satellite) with the same wifi name to make...
- Jul 27, 2023
Can install the RBS from the 2nd RBK system. The RBR from the 2nd RBK system can only work as the main router or in AP mode.
JohnHighrock
Tks Furry !
Understood for the RBS. Easy.
What is the AP mode for the second RBR ?
Merci 😉
Merci 😉
Jul 27, 2023Guru - Experienced User
AP mode turns the RBR into a separate kind of working RBS that has to be connected via ethernet cable and would run it's own separate wifi SSID name and channels. Wont integrate into the main RBK system but can help provide additional coverage if needed in this capacity.
https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Try option #2 first...
https://kb.netgear.com/000061277/Which-features-are-disabled-on-my-Orbi-router-when-it-is-set-to-AP-Mode
- JohnHighrockJul 27, 2023Aspirant
Crystal clear, Top !
Tks a lot Sir- FURRYe38Jul 27, 2023Guru - Experienced User
