Dorkapotomus
Apr 22, 2018Follower
Echo multi room doesn’t work when one echo is on the router and one is one the satalite.
Title has the details. Same WiFi network but since one is on the router and one is on the satalite they believe they are on different networks. Any ideas? Is this just a flaw with the echo?
Apr 22, 2018Guru - Experienced User
What model orbi system do you have?
What FW is loaded on the orbi system?
Is the Echo devices working?
