FCO100
Nov 16, 2025Aspirant
Edit/Add new IP reservations
I have an RBR50v2 Orbi router and 2 satellites with FW ver 2.7.5.6. I have entered 15, or so, reserved internal IP addresses using "Advanced > Security > Access Control". All works well. The is...
FCO100
Nov 17, 2025Aspirant
Thank you guys for your replies. StephenB, sorry, you are right, I mean Advanced > Setup > LAN Setup.
So if I edit (change existing) an IP address or MAC address using "Advanced > Setup > LAN Setup", I should wait for a period of time for the changes to take place? Any idea of how long (order of magnitude) I will need to wait? I presume the timing is a product of my ISP, but normally 1hr, several hrs, next day?
I should be able to add a new IP address which should take place right away, correct?
Thanks again for all your help.
KevinLiT
Nov 18, 2025NETGEAR Moderator
Hello FCO100,
Welcome to the NETGEAR Community!
I understand that you are not able to view your IP address assignments through your attached devices. Please try resolving this issue by using a different web browser such as Mozilla Firefox. Also check the IP assignments on each of your devices individually to verify successful IP address assignments.
Best,
Kevin
Community Team
