FCO100
Nov 16, 2025Aspirant
Edit/Add new IP reservations
I have an RBR50v2 Orbi router and 2 satellites with FW ver 2.7.5.6. I have entered 15, or so, reserved internal IP addresses using "Advanced > Security > Access Control". All works well. The is...
CrimpOn
Nov 23, 2025Guru - Experienced User
FCO100 wrote:Can I delete all the devices that I think are not needed any more?
Certainly. I agree with StephenB that Access Control is more trouble than it could possibly be worth, so I never enable it. If one of those devices happens to return and the user remembers my WiFi password, it simply gets connected. I also clear the table under that one. (Blocked Devices that are not connected - just in case anything got put into that table.)
