BretD
Oct 31, 2017Administrator
EERO Gen 2 Vs Orbi - What’s the Fastest WiFi Mesh System? TheWirecutter.com
TheWirecutter.com pit EERO Gen 2 vs. Orbi vs. Plume and even Google WiFi and other WiFi systems. See how Orbi Wins the WiFi Race
HockeyStick
Oct 31, 2017Star
Since the Orbi is a piece of garbage that will drop your connection continuously, I'd vote for any other product other than this one. I wish I had never purchased mine.
- Mikey94025Oct 31, 2017Hero
HockeyStick wrote:Since the Orbi is a piece of garbage that will drop your connection continuously, I'd vote for any other product other than this one. I wish I had never purchased mine.
Fortunately, the Orbi works great in my household and doesn't "drop my connection continuously."
- ElyOct 31, 2017Luminary
Orbi is an awesome product, simply the best Wi-Fi I have ever owned in over 25 years using the internet.
- dpdurstNov 01, 2017Luminary
A few hiccups here and there but outside of this the Orbi has rocked it and performance beats anything else so far I have installed. I'll keep my Orbi thanks..
- SnorkyNov 02, 2017Star
Unfortunately, mine drops connection and reconnects about every 10 minutes. Orbi connected to Netgear C3700 Cable Modem/Router.
I have moved satellite 2 3 different locations, same problem since day (about a month now).
- martyfpNov 06, 2017Luminary
Apart from early hiccups, our Orbi has been very stable and dishes out great wifi around the house. Our previous head-spot issues are behind us.
If Netgear add a working the QoS support and USB drive capabilities to the Orbi then it would be perfect.
- NETthisGEARDec 12, 2017Apprentice
Keep in mind that the Orbi can Daisy chain. Some people don't realize that.
- GuyfromunionNov 20, 2017AspirantI have to agree My orbi drops connections all the time.
- VillagesAVNov 25, 2017InitiateI was an early adopter to Orbi and the internet may not be available was so annoying I had to buy the gen 2 EERO Pro Set a few weeks back. No more random drops, just a solid connection in all corners of my home. The Orbi is now a $350 doorstop. Get your sh$£ together Netgear, this products firmware needs alot of work. Stability 1st
- Greyhawk68Nov 25, 2017Star
I bought the Orbi for the speed and the dedicated backhaul channel (and the ethernet ports. It's been stable since I got it last January, but since the end of October it frequently disconnects. I've tried every remedy people have suggested here and none have worked. It's beyond frustrating at this point and is driving me crazy. I'm not alone. For those that it's still working perfectly, I'm happy for you, because I don't want to you to go through what many of us are.
When it works, it's brilliant, but when it disconnects several times a day and leaves everything in limbo, it's a huge pain.
