BretD
Oct 31, 2017Administrator
EERO Gen 2 Vs Orbi - What’s the Fastest WiFi Mesh System? TheWirecutter.com
TheWirecutter.com pit EERO Gen 2 vs. Orbi vs. Plume and even Google WiFi and other WiFi systems. See how Orbi Wins the WiFi Race
RogerSC
Dec 03, 2017Virtuoso
tagteam wrote:
RogerSC wrote:...The Orbi auto-flashes the latest firmware eventually. It may take several days, but it will happen...
If there is one thing I could change about the system, that would be it = allow users to disable firmware auto-updates. I imagine that would be a relatively simple option to add to the firmware and the default could be set to "enable".
Trying something different here...my "main" wired-only router is an R7800, and the Orbi is in AP mode. I've put dd-wrt firmware on the R7800, and have blocked "downloads.netgear.com". Waiting to see if that prevents auto-upgrade or not. I can't go to downloads.netgear.com from the Orbi, so I know that URL is blocked. In fact, to download firmware manually from Netgear, I have to remove the restriction in the R7800 firmware settings and then put it back when I'm done. So I think that there's a chance...
tagteam
Outstanding idea which, I suspect, will eliminate those auto-updates.
Regardless, Netgear needs to include a "disable" option since many users, including myself, have Orbi configured as a router.
