vtrusty
Aug 14, 2017Star
Enable Upstream QoS (Optimized for Gaming) - "Qos bandwidth of Mbps should be 1 to undefined." error
Does anyone else have trouble trying to modify the "Enable Upstream QoS (Optimized for Gaming)" value from the QOS_main.htm page? It defaults to 512Kbps...which seems pretty low. If i change it to an...
Anonymous
Aug 14, 2017That is an incomplete page and is not supported at this time.
- vtrustyAug 14, 2017Starso the only QOS feature we have currently is the Speedtest?
- cpd5215Aug 14, 2017Guide
You got it
- AnonymousAug 14, 2017
vtrusty wrote:
so the only QOS feature we have currently is the Speedtest?Correct.
- martyfpAug 15, 2017Luminary
Out of the box - does Orbi do ANY form of QoS ? i.e. is the Orbi Dynamic QoS enabled by default or does it only kick in after running the speedtest ?
Other Netgear router instructions imply that you need to run the speedtest or manually enter your connection speed in order to get Dynamic QoS to start working.
btw. I have played with the hidden QoS pages but they dont' appear functional.
