vtrusty
Aug 14, 2017Star
Enable Upstream QoS (Optimized for Gaming) - "Qos bandwidth of Mbps should be 1 to undefined." error
Does anyone else have trouble trying to modify the "Enable Upstream QoS (Optimized for Gaming)" value from the QOS_main.htm page? It defaults to 512Kbps...which seems pretty low. If i change it to an...
Anonymous
Aug 14, 2017That is an incomplete page and is not supported at this time.
vtrusty
Aug 14, 2017Star
so the only QOS feature we have currently is the Speedtest?
- cpd5215Aug 14, 2017Guide
You got it
- AnonymousAug 14, 2017
vtrusty wrote:
so the only QOS feature we have currently is the Speedtest?Correct.
- martyfpAug 15, 2017Luminary
Out of the box - does Orbi do ANY form of QoS ? i.e. is the Orbi Dynamic QoS enabled by default or does it only kick in after running the speedtest ?
Other Netgear router instructions imply that you need to run the speedtest or manually enter your connection speed in order to get Dynamic QoS to start working.
btw. I have played with the hidden QoS pages but they dont' appear functional.
- martyfpAug 18, 2017Luminary
I have played with eh QoS settings in the hidden menus and only managed to completely mess up my system - IPTV and Wireless surround sound started behaving very erratically. The only thing I could do to get things working properly again was a factory reset :smileyfrustrated:
My own fault for fiddling with something that is not released so not complaining. However I really would like to get this working.
My question remains though: I sany form of Dynamic QoS running by default on the Orbi and is it related to the running the speedtest (which I have not done after factory reset) ?
