brewingbrad
Jan 28, 2018Star
Ethernet backhaul causes crash if anything else is on the switch
I've heard of others having issues with ethernet backhaul. I suspect mine is similar. Short story: if any device other than the connection for ethernet backhaul is connected to the satellite or route...
DarrenM
Jan 30, 2018Sr. NETGEAR Moderator
Do you have a switch connected to the orbi? or another type of router?
DarrenM
- brewingbradJan 30, 2018StarNo, the connection is Orbi router to Orbi satellite.
- brewingbradJan 31, 2018Star
Tried it with a switch between just for **bleep**s. Same result.
- DarrenMJan 31, 2018Sr. NETGEAR Moderator
I want to get you in contact with support send me a PM with your name email and phone number and I will get you with support.
DarrenM
