brewingbrad
Jan 28, 2018Star
Ethernet backhaul causes crash if anything else is on the switch
I've heard of others having issues with ethernet backhaul. I suspect mine is similar. Short story: if any device other than the connection for ethernet backhaul is connected to the satellite or route...
danny07
Jul 23, 2018Tutor
Last night my Orbi developed this problem. It had functioned flawlessly for almost 2 months. I have one satellite connected by ethernet backhaul, and one connected wirelessly. This morning had not internet access. When I tried to ping the router it would not reply. I unplugged all of the ethernet connections and it immediately began to reply. One by one I went through unplugging my wired devices to figure out which device was causing the main Orbi to crash, and upon unplugging the ethernet backhaul to the Orbi satellite, it began responding to pings. Strange. It had worked fine in that configuration. Anyway, everything is working again, as long as the ethernet isn't plugged in to the Orbi satellite.
Sep 14, 2018Guru - Experienced User
Let u know how it goes. You should be able to get back haul going. Just start with the satelite, switch, router and wired PC first. Set up wireless first then wait for BLUE led, then connect LAN cable to the satellite and wait for the BLUE led to appear on the satellite. Set a IP address reservation, save and apply. Then connect the rest of the LAN network devices.
You can also try the beta FW as well:
Ethernet back haul does work!!!
