Zorat
Aug 19, 2018Tutor
Ethernet Backhaul is freezing up WiFi completely and kicking everyone off (RBR50) & (RBS50)
I have factory reset these both multiple times. I have tried to originally connect them wirelessly, and then shut off the Satellite, and plug it into ethernet, and then turn it back on. This locks up...
- Aug 19, 2018
Have you tried simply waiting? Recognition of wired backhaul takes minutes, not seconds. It generally takes 5 minutes per satellite for my system to stabilize after starting up each wired satellite one at a time.
One theory is that wiring a satellite causes it to use the same LAN address simultaneously for both wired and wireless interfaces, resulting in the storm you see. But the system eventually figures out that it's wired and shuts off the wireless backhaul. This is just a theory, I don't know whether it's the true explanation.
Aug 26, 2018Guru - Experienced User
Your systems maybe faulty as well. If you all are having problems getting your systems setup for wired back haul or have wireless performance problems, I would return the system or ask NG support for and RMA. Some other users have expressed similar problems and some have recieved new RMAs and seems to have fixed there problems.
Good Luck.
Zorat
Aug 26, 2018Tutor
Good idea. Will give that a try.
