RocketSquirrel
Feb 22, 2018Luminary
Ethernet backhaul kills entire network
I'm just setting up my Orbi system today for the first time. I have a big house which is wired for Cat5e, and I want to use Ethernet backhaul. I have 2 satellites. All 3 units are updated to the late...
Feb 22, 2018Guru - Experienced User
Mines a 5000sq ft house two story, I currently have my Orbi AC2200 router set up on 2nd story of one side of my house and the Satellite at the far end of the house and after getting up and running, the range and performances are wonderful. I'm only using 1 Satallite. I have a NG wireless bridge connected to the Satellite at the far end that services a DISH Joey for my mom in law and Bro in laws PC LAN connected to the back of the Satellite. IT's not using any ethernet currently however i do have LAN there if needed. I have a few switches, however all non manages swtiches. I haven't tried connecting the Satellite with LAN yet.
I recommend leaving the LAN disconnected like previously mentioned. There maybe issues in FW preventing LAN connection with the Satellite. You could run a test and connect the Satellite directly to the Orbi router to make sure the switches involvement is ruled out.
