RocketSquirrel
Feb 22, 2018Luminary
Ethernet backhaul kills entire network
I'm just setting up my Orbi system today for the first time. I have a big house which is wired for Cat5e, and I want to use Ethernet backhaul. I have 2 satellites. All 3 units are updated to the late...
Feb 23, 2018Guru - Experienced User
Sorry, posted wrong picture:
budy
Feb 24, 2018Luminary
Check, if any of your other switches has STP enabled and if yes, check with bridge IDs are in place. Also… the Orbi gear seems to make heavy use of multicats for configuration, it might be also worth wile to take a look at that. Maybethe Orbi and you cable provicer utilize the same multicast groups, that woudl surely disrupt your traffic.
