RocketSquirrel
Feb 22, 2018Luminary
Ethernet backhaul kills entire network
I'm just setting up my Orbi system today for the first time. I have a big house which is wired for Cat5e, and I want to use Ethernet backhaul. I have 2 satellites. All 3 units are updated to the late...
Feb 27, 2018Guru - Experienced User
Was curious about the status on this? You get this working?
RocketSquirrelwrote:I'm just setting up my Orbi system today for the first time. I have a big house which is wired for Cat5e, and I want to use Ethernet backhaul. I have 2 satellites. All 3 units are updated to the latest firmware as of today.
The problem is that when I connect either satellite to my LAN via Ethernet, the entire network becomes inaccessible. I can't even ping the router from my wired PC. When I unplug Ethernet from the satellites and reboot them, the network works, but the satellites are too far from the router to connect.
Is there perhaps a conflicting setting which prevents Ethernet backhaul? Any suggestions welcome!
RocketSquirrel
Mar 01, 2018Luminary
Not yet. I have a newer firmware to try, but need to wait until other users won’t be disrupted.
- FURRYe38Mar 01, 2018Guru - Experienced User
OK. I need to test this again as well with newer FW. Last time it was working fine. I had to disconnect as I was testing a different configuration with the Satellite.
Keep us posted.
- RocketSquirrelMar 02, 2018Luminary
The 2.2 firmware remedies this issue and seems to work well overall. Hopefully Netgear will promote it to full public release soon.
- FURRYe38Mar 03, 2018Guru - Experienced User
Good to hear. I re-enabled back haul here as well. Working great. Hope it will be relased soon.
