garyslaben's avatar
garyslaben
Follower
Jan 11, 2018
Ethernet Backhaul
I originally set up the system with wireless backhaul.  Just now reconfigured as wired.  Router status still shows satellites connected as 5G.  Do I need to reset the satellites or perform some other function to "forget" the wireless backhaul and use the ethernet connection?
  • I actually have the same issue. Did you manage to fix it in the end? I am running firmware 2.1.2.18 (the latest) and I have connected a Cat 6e cable between the router and satellite. Daisy Chaining option is on and everything looks good.
    The problem is, the connection mode of the satellite is still 5G. The status was showing Config Sync for a few hours and now shows Good.
    I tried resetting the satellite and have power cycled both devices a few times but can't get the Satellite connection mode changed to Wired.
    Is there anything specific I have to do which I am not doing?
    • def1ant's avatar
      def1ant
      Initiate
      Tried the same thing.  The latest firmware is super flaky when it comes to wired backhaul.  Mine was saying wireless when it was wired and then it brought the whole network down.
      • budy's avatar
        budy
        Luminary
        The issue with the GUI is, that is sometimes even shows nonsense. I had been running my satellite via wired backhaul, before I upgraded to 2.1.2.18 and afterwards, the satellite vanished from the status page, but remained working nonetheless.
        I finally reset the satellite to factory defaults and performed a wireless sync. Afterwards, it was just simply plugging in the ethernet cable.
  • Thanks for the replies guys!
    So I did some testing and realised that while my cable was working when installed, it has now apparently stopped working (very strange!). I took it out and plugged it into a laptop to test.
    So I am waiting on a new cable to come to me by tomorrow and will update on findings with the new cable.
  • So I got the new cable and everything is installed. But for some reason, every time I plug the cable in, it generates a huge packet storm over the network and everything disconnects or gets very unstable. I have tried a few times already and recently just restarted both router and satellite and trying out again.
    It's just giving me no confidence as it goes down any time it likes. I have the router setup as a router, not as an AP too.
    I really hope they update the firmware to make it more stable. It's really bad right now.
    EDIT: While I was typing this out, the whole network went down again. I had to unplug the cable and leave it unplugged to make it work again and post this reply.
    • budy's avatar
      budy
      Luminary
      Hi,
      if you get the chance to login into your router via telnet, you could check the STP parameters of your network, because STP should prevent such events… Also, do you happen to have anothet router in your system?
      • vseera's avatar
        vseera
        Guide
        Hi,
        Just a regular telnet session to my router's IP doesn't work. Is there anything special I need to do to telnet into it? Also, how do I check the STP?
        I have another router on my network but its DHCP server as well as Wifi is disabled and it is being used as an access point, to connect one room with multiple devices (via its gigabit ports).
        I can try taking this off the network but it's not a solution for me, as I need this device for my file server etc to talk to the rest of the network.
